Issue Token from Portal for ArcGIS
  • Feb 18, 2025 7:15 PM UTC
  • 82 views
vxn43
Forum|alt.badge.img+20
I have provided a consultant with the URL to one of my geocoder services. In order for them to access it, I need to issue a token. The token is issued in the Portal, which means it is valid for a maximum of two weeks. Currently, I have to issue a token every two weeks, a manual process.
I would like FME to issue a token and then email it to the recipient. I know how to do the email part, but is it possible for FME to contact the Portal and issue a token?
My ultimate goal would be to add this workbench to an Automation and have the token automatically issued every two weeks.
Best answer by hkingsbury
You’d call the generateToken end point in FME- https://developers.arcgis.com/rest/users-groups-and-items/generate-token/.
A much easier way would be to provide your consultant what a login to Portal. That way they can use the credentials to connect to the service
hkingsbury
Forum|alt.badge.img+73
  • Feb 19, 2025 10:19 PM UTC
