Issue querying licenses in use
  • Feb 5, 2021 5:58 PM UTC
  • 70 views
Hi :
We are trying to use the fmelicensingassistant_cmd utility to check for FME Desktop license counts prior to running some of our scripts that launches (fme.exe). Without doing this pre step, we end up triggering a very unfriendly error when no licenses are available, and users would think the system is broken.
From my testing so far, it seems the utility is always returning 1 more license being used than actuals. (as compared to running the LMTOOLS on the licensing server) And, if all licenses are actually in use, the utility will take roughly a minute to respond, at which point it will still, report that all licenses are in use. Neither is desirable and this behavior prevents us from actually determining available licenses. Is there anything I am doing wrong?
By the way the specific license type we are looking at is the Smallworld license.
This is the command I'm running:
fmelicensingassistant_cmd.exe --query <servername>:27000
Any help appreciated!
Best answer by hkingsbury
We run a similar process as a .bat script
@echo off
echo Start Report
echo FME License
echo FME Licence > "<some file>.txt"
echo ############## >> "<some file>.txt"
lmutil.exe lmstat -c @<server> -a >>  "<some file>.txt"
echo Finished >>  "<some file>.txt"
echo Finished
notepad.exe "<some file>.txt"
@echo on
hkingsbury
Forum|alt.badge.img+73
  • Feb 8, 2021 7:58 PM UTC
@echo off
echo Start Report
echo FME License
echo Finished
@echo on
