Is it possible to remove hidden attributes without having to expose them first?
  • Jul 20, 2017 9:36 AM UTC
  • 6 replies
  • 589 views
Forum|alt.badge.img+54
Transformers such as the matcher appear to use hidden attributes to match on when the attribute matching strategy is set to match all attributes. Is it possible to remove hidden attributes without exposing them first?
Best answer by david_r
You're right, it seems like the fme_* attributes enjoy some special protection by the BulkAttributeRemover.
Try this Python script in a PythonCaller instead:
import fmeobjects
def RemoveFMEAttributes(feature):
    for attrib in feature.getAllAttributeNames():
        if attrib.startswith('fme_'):
            feature.removeAttribute(attrib)
Tested with FME 2017 and seems to do the job.
  • Jul 20, 2017 9:38 AM UTC
You can use the BulkAttributeRemover.
  • Jul 20, 2017 9:50 AM UTC
Doesn't appear to let you remove any hidden attributes that start with fme_
  • Jul 20, 2017 9:57 AM UTC
import fmeobjects
  • Jul 20, 2017 12:02 PM UTC
import fmeobjects
There is an extremely convenient method if you want to remove every fme_* attribute :-)
def removeFMEAttributes(feature):
    feature.removeAttrsWithPrefix('fme_')
  • Jul 20, 2017 3:00 PM UTC
Alternatively, the FMEFunctionCaller with this function call setting could also work fine.
@RemoveAttributes(fme_pcre_match,^fme_)
thejando
Forum|alt.badge.img+4
  • Sep 11, 2019 5:46 AM UTC
import fmeobjects
...and don't forget about the "multi_reader_*" FME feature attributes, and the format-specific attributes like "geodb_*" for Esri Geodatabases. Also beware of the OBJECTID and SHAPE.LEN and SHAPE.AREA if they have been accidentally included in the User Attributes for some Esri formats.
