Invoking WorkspaceRunner upon completion of FME processing
  • Mar 12, 2013 10:27 PM UTC
  • 11 replies
  • 165 views
Hello:
I have two FME programs:
1) Loads data in one spatial table
2) Loads data in another spatial table
I would like to :
- Keep these scripts independent, so script 1 can run on demand and to its thing, and
- Script 2) can call script 1), for extra processing.
My problem is, how do I invoke Script 1) from Script 2)?
They both do different data processing, but it will be great if one can call the other.
I am struglling with how to invoke Script 1, because there is no way "to trigger" its processing. I would like that, once Script 2 is done, it automatically triggers Script 1.
Is this possible to do? I have been trying to do this with WorkspaceRunner, but I don`t get it to "run"
Thanks again.
Richard.
Best answer by david_r
Hi Richard,
you can do this by writing a small Python shutdown script, using the FMEWorkspaceRunner API. This small example, used from worspace1, executes workspace2 when workspace1 completes:
import fmeobjects current_workspace_dir = FME_MacroValues["FME_MF_DIR_UNIX_MASTER"] wsr = fmeobjects.FMEWorkspaceRunner() wsr.runWithParameters(current_workspace_dir+"/workspace2.fmw",     {"SourceDataset_SHAPE": FME_MacroValues["DestDataset_SHAPE"]}) ------
It also transfers a parameter from workspace1 to workspace2. Tested using FME2012. Let me know if you have questions to the above.
Hope this helps.
David
  • Mar 12, 2013 10:41 PM UTC
With WorkspaceRunner you can set it to Wait for Job to Complete for 'Script2', then use a second WorkspaceRunner to run 'Script1' .
I assume you mean a Workbench when you say scripts.
  • Mar 13, 2013 4:42 AM UTC
Nevertheless, I think using a third workspace with 2 WorkspaceRunners is the best way.
You can use a Creator transformer as "input" (i.e. the trigger to run Script 2) of the third workspace.
Creator: create 1 feature as trigger
--> WorkspaceRunner: run Script 2 * Wait for Job to Complete = yes
--> WorkspaceRunner: run Script 1
  • Mar 13, 2013 5:02 AM UTC
Hi Takashi: I agree with you, but unfortunately, I need to adhere to some standards and requirements to resolve this problem and unfortunately using three scripts is out of the question. I truly appreciate your help though. There must be a way to do this. I continue investigating :) Best regards Richard
  • Mar 13, 2013 5:16 AM UTC
Running Script 1 by using command-line in the shutdown script of Script 2 may be possible. But I think it's not a general way, I don't recommend it if there are other usual ways.
  • Mar 13, 2013 6:56 AM UTC
Hi Richard,
Hope this helps.
David
sigtill
Forum|alt.badge.img+25
  • Mar 13, 2013 8:38 AM UTC
David, nice demo. Anything to think about when porting this to FME Server?
  • Mar 13, 2013 9:03 AM UTC
Hi Sig,
I'd be delighted if somebody had the time to test my solution with FME Server. I have made my demo workspaces available here.
If you're able to test it, please let me know how it works.
David
  • Mar 13, 2013 9:10 AM UTC
Nice - I'll add that to my inventory Thanks!
mark2atsafe
Forum|alt.badge.img+59
To maybe summarise the answers for the original poster:
1) You can use a WorkspaceRunner in Script2 to call Script1. You just need something to trigger it once. Use a Creator or a Sampler transformer to get a trigger feature.
2) If you do use a WorkspaceRunner, one issue is that Script2 won't be fully completed - because its writers won't have finished - when Script1 is triggered. If this is a problem (and it might not be for you) the only solution (using WorkspaceRunners) is to use a third (control) workspace to run Script2 then Script1, waiting for Script2 to complete.
3) A shutdown script can be used instead. It won't be triggered until Script2 is complete, which solves the WorkspaceRunner issue in #2. The one thing I would add to David's script is a check for the status of Script2. In Tcl it would be:  if {$FME_Status == "1"} ..... because you probably won't want to run Script1 if Script2 has failed.
Two other methods I'll mention:
4) If Script2 writes to a database, set a trigger in the database to run Script1
5) If you have FME Server, then you can set up a Notification/Alert to run Script1 in response to Script2.
Hope this is useful. Thanks to everyone for the great suggestions.
Mark
Mark Ireland
Product Evangelist, Safe Software Inc.
  • Mar 13, 2013 4:34 PM UTC
Mark, very good idea to check for the workspace status in the shutdown script.
For reference, here is the modified Python shutdown script with your suggestion included:
import fmeobjects   if FME_Status == 1:     current_workspace_dir = FME_MacroValues["FME_MF_DIR_UNIX_MASTER"]     wsr = fmeobjects.FMEWorkspaceRunner()     wsr.runWithParameters(current_workspace_dir+"/workspace2.fmw",         {"SourceDataset_SHAPE": FME_MacroValues["DestDataset_SHAPE"]}) -----
Just watch those indents and newlines in the script above, this forum system isn't too kind with code.
David
  • Mar 14, 2013 5:24 PM UTC
Hello again:
Thanks for all the advice, it is much appreciated. I have finally got everyone here to decide that we will use only two scripts and I have a portion of code in Python that we need to incorporate to achieve what we need.
Is there any "friendly" way to incorporate Python code in the FME Workbench? Or should I edit the FMW file in a text editor?
Thank you!
Richard
