I'm running two instances of FME on the same machine, one 64 bit (running with a long-running job), and one 32 bit running a small job.
Whenever I enable "full inspection" in the 32 bit instance, the 64 bit instance immediatedly responds by turning full inspection on here as well, at least visually.
Is there a "leakage" of settings between multiple instances of FME, even across the 32/64 divide ?
Is this "leakage" real, or just an unwarranted display issue ?
Cheers
Lars I.
