Input Ordered parameter doesn't work in FME 2017?
  • Mar 19, 2017 8:30 AM UTC
  • 43 views
Hi there, I don't think the Input Ordered parameter (Input is Ordered by Group in older versions) works properly in FME 2017.0 build 17271. See the following movies and attached workspace: - created with FME 2016.1.3.2 build 16717
Run the attached workspace with FME 2016.1.3.2 build 16717. Looks good.
Run the same workspace with FME 2017.0.0.1 build 17271. The PointCloudCombiner seems to cache all input features before starting processing, even if the Input is Ordered by Group parameter is set to Yes.
Am I missing something?
fmelizard
Forum|alt.badge.img+22
  • Mar 20, 2017 9:21 PM UTC
Hi @takashi. I was able to reproduce what you reported with the Input is Ordered by Group parameter set to Yes in FME 2017.0 build 17259 and FME 2017.0.0.1 build 17271. I filed a report for Development to investigate and will let you know when I receive a reply from them, known issue 76579. Thanks!
  • Mar 22, 2017 11:32 AM UTC
Hi @NatalieAtSafe, thanks for filing the problem report.
The parameter in the Aggregator seems to work as expected, but the NumericRasterizer seems to have this issue too. I'm afraid that more transformers could have the same issue. Perhaps have to check all transformers which have the Input Ordered parameter.
