InlineQuerier - how much of SQLite SQL is implemented ?
  • Feb 26, 2026 10:52 AM UTC
  • 90 views
lifalin2016
Forum|alt.badge.img+42
Hi.
I’m looking into whether I can use InlineQuerier for a Workbench validation of data using a list of criterias.
One of the things I need to do is use RegEx, and is thus trying to use the REGEXP construct mentioned in the documentation. However, this is the error I’m getting:
InlineQuerier_2 (InlineQueryFactory): Error preparing database query: no such function: REGEXP Unable to execute statement
The full query is here:
SELECT *
FROM "Data"
WHERE
NOT((
"tvaersnitsform" IS NULL
OR
"tvaersnitsform" REGEXP '^(other: )[0-9a-zA-ZæøåÆØÅ]{2,}$'
OR
"tvaersnitsform" IN (SELECT "key" FROM "LOOKUP.Tvaersnitsformtype")
If I remove the REGEXP part of the criteria, it works just fine.
Has anyone used InlineQuerier much, and have some insights into what might be wrong here ?
Is it just a subset of SQLite’s SQL language being available in InlineQuerier ?
If I click the dialog Help button, it leads me to a page, that clearly shows REGEXP.
Cheers.
Best answer by david_r
From the SQLite documentation:
The REGEXP operator is a special syntax for the regexp() user function. No regexp() user function is defined by default and so use of the REGEXP operator will normally result in an error message.
It seems that the REGEXP functionality isn’t built into SQLite, and to use it you’ll have to supply the regex function yourself. I suspect this isn’t possible from the InlineQuerier.
  • Feb 26, 2026 11:51 AM UTC
lifalin2016
  • Feb 27, 2026 7:49 AM UTC
That sounds peculiar, since Regex is a well established standard afaik.
But it might have been done to keep SQLite as light as possible ?
Alas, this will be a deal breaker for me. I’ll have to explore other possible avenues then.
Thanks.
  • Feb 27, 2026 12:03 PM UTC
Indeed. SQLite is very much optimized for speed and size (of the executable), so default behavior has several “gotchas” that can be confusing or unexpected if you deviate from simple usage. If so, careful consultation of the documentation is necessary.
For example, by default foreign key constraints aren’t enforced unless you specifically ask it to. This is contrary to almost any other RDBMS.
