Import several excels with the same schema from one folder as different features
  • Feb 7, 2022 2:51 PM UTC
  • 81 views
Hello, I'm working with FME2020. I want to import several excel files with the same schema from one folder as different features. With a xlsx-reader (select multiple folders/files) all files are written in one feature. With a path reader I can't define a schema. Is there a way to read all the files with one reader or do I have to use one reader per file? Thanks in advance
alexlynch3450
Forum|alt.badge.img+16
Path reader => test filter => FeatureReader @Value(path_windows)
assuming youre working on windows os.
