Identifying numbers represented by polygon shapes
  • February 4, 2025
  • 21 views
dustin
Forum|alt.badge.img+31
I have a unique problem. I have a set of polygons which take the shape of numbers. In the example below, the number 1875 has been extracted from a raster. As it sits, the 4 numbers are separated but could easily be aggregated. I’m looking for a way to convert this value ‘1875’ to an integer attribute.
I can’t think of a way apart from some kind of AI solution, but thought I’d ask the collective to see if anyone has any thoughts?
dustin
  • February 4, 2025
@Mods, Please move this to the FME Form section of the community. Thanks.
s.jager
Forum|alt.badge.img+16
  • February 4, 2025
OCR has been around for ages, doesn't your scanning software allow you to convert to text?
Anyway, try the TesseractCaller, I would suggest...
