I am trying to transfer attribute values on rational bases of length.
  • Oct 29, 2018 3:38 PM UTC
  • 42 views
I have to two geometry (Polyline), segment lengths are different and spatial aligned. I want to transfer the attribute of 2nd geometry to 1st geometry? Some attributes of the segment are calculated on the bases of length. I only need to transfer attribute which is overlaped by 1st geometry segment.
Best answer by philippeb
If the two segments are overlapping, you could use LineOnLineOverlayer or a NeighborFinder.
In the parameters don't forget to merge the attributes ;)
philippeb
Forum|alt.badge.img+23
  • Oct 29, 2018 4:10 PM UTC
