How to write URL values embedded into text strings into an attribute field in a Shapefile
  • Mar 27, 2019 7:26 PM UTC
  • 54 views
For example, if the shapefile contain an attribute filed called 'CONTACT' and need to populate its rows with following URLs embedded to display as text strings (display text) instead of actual URL vales as follows.
CONTACT
Safe
Esri
itay
Forum|alt.badge.img+19
  • Mar 27, 2019 7:37 PM UTC
Hi @tordr,
If you have a limited number of URL that you want to display as text, then I would suggest using the AttributeValueMapper to create a new attribute (text) to populate the shapefile attribute values.
Another approach would be to use conditional statements in an AttributeCreator or AttributeManager.
Hope this helps,
Itay
