How to use 'Write Microsoft Word (.docx) with FME' to create multiple tables in a single document?
  • May 20, 2016 9:23 AM UTC
  • 258 views
Hi
I’m currently using the workspace ‘Write Microsoft Word (.docx) with FME’ to produce a report which highlights errors with in the data.
What I would like to know is how using this workspace can I create a single word document with multiple tables?
Each table will be showing different attribute errors depending on its output from a single workspace.
Thanks
Andy
mygis
Forum|alt.badge.img+14
  • May 25, 2016 10:17 AM UTC
Hi @aussie72 Could you provide us with the sample MS Word document also the source data
ciarab
Forum|alt.badge.img+10
  • Nov 4, 2016 2:30 PM UTC
@aussie72 I noticed this query come up when doing a search for my own question. The solution to creating multiple tables within the single word document is contained in here. I had a similar request to yours.
https://knowledge.safe.com/questions/33377/creating-a-vertical-table.html?childToView=36217#answer-36217
