How to use Environment Variables in User Parameters ?
  • Mar 15, 2016 11:36 AM UTC
  • 15 replies
  • 1013 views
ari
Forum|alt.badge.img+4
Hello,
I'm working with FME Desktop 2015 with a WorkspaceRunner transformer calling several workspaces where i have to use an environment variable in the path of some private variables.
For example: %ENVIRONVAR%\\dat\\myfile.txt
The problem is that the called workspaces don't recognize the value of the environment variable defined by the Windows System. I have tried to assign the value to the environment variable inside the workspace but it is not a good solution in this case because every PC could have a different value.
Is there some example about to do solve this problem?
Many thanks in advance!
A.
Best answer by mark2atsafe
Use ${variablename} and that should work, for example: ${ENVIRONVAR}\\dat\\myfile.txt
  • Mar 15, 2016 11:41 AM UTC
Hi @ari, can the EnvironmentVariableFetcher transformer help you?
  • Mar 15, 2016 11:42 AM UTC
Hi
Are you using the EnvironmentVariableFetcher?
Be aware that environment variables defined while a program (e.g. FME) is running won't be available to that program until it restarts.
David
mark2atsafe
Forum|alt.badge.img+59
  • Mar 15, 2016 3:13 PM UTC
ari
  • Mar 16, 2016 9:12 AM UTC
Thks Takashi, David & Mark for your anwers !
@Mark, I don't understand the reason but this solution doesn't work. I think it's the most logical way to do it and It was the first thing that i tried but I get this error message:
Undefined macro `ENVIRONVAR' dereferenced in file `file.fmw'. Program Terminating
@Takashi, @David, I haven't used before the EnvironmentVariableFetcher transformer, I would take in consideraton for future ocassions.
Finally, I solved the problem with a Private Scripted (Python) Parameter (myparam) that gets the value of the environment variable:
import os
return os.environ['ENVIRONVAR']
and then using this parameter in that way ... $(myparam)/dat/file.dat
Clearly, this is a workaround to do the same that i think it would have to do the direct assign of the environment variable :(
Thanks,
A.
mark2atsafe
import os
Thanks,
A.
That's odd @ari - are you sure you were using curly braces {} and not round ones ()
ari
  • Mar 17, 2016 12:03 PM UTC
Wow, It works ... :-D
Thanks a lot @Mark !
A.
The curly braces not working at 2017.0
So, I needed to restart services after creating environment variable. Sorry.
rwhittington
  • May 21, 2019 9:20 PM UTC
Hi @mark2atsafe Thanks for this tip....this works well within the engine...but the environment variables in paths doesnt quite work within workbench for example when the FeatureReader wants to scan the dataset the environment variable in a path does not resolve.
mark2atsafe
fyi for everyone following this, I've filed the issue of environment variables in the FeatureReader (FMEENGINE-60160) and we'll wait and see what the developers can do for us.
ssharp
Participant
  • Participant
  • Mar 7, 2022 9:35 PM UTC
Has this "limitation" be address? Which approach is considered a FME developer "best practice", 1) EnvironmentVariableFetcher or 2) inline reference ${variablename}?
mark2atsafe
Unfortunately, no. The management team told me that this isn't meant to be supported, which is a shame. Given that, I think the EnvironmentVariableFetcher transformer is perhaps the best practice solution. It's an extra transformer to add, but it is the most guaranteed to work.
  • Feb 2, 2023 10:02 PM UTC
@mark2atsafe​ ; @david_r​
i have trouble using variable environmental in feature writer transformer:
in dataset i use : ${KMOCShape}\\Facilities. I doesn't work. please advise. thanks. - it actually creates a folder ${KMOCShape}\\Facilities at the same location of its workspace.
  • Feb 3, 2023 8:36 AM UTC
If you're referring to a published parameter, you have to use parenthesis, not brackets. For example:
$(KMOCShape)\Facilities
If you're indeed referring an OS environment variable, I'd try using an EnvironmentVariableFetcher before the writer and using its output attribute in the writer path.
  • Feb 3, 2023 2:32 PM UTC
Thanks @david_r​ !! using parenthesis, i has the same issue as using brackets. it works with EnvironmentVaribaleFetcher. Thanks again!
