how to update metadata in file geodatabase with multiple feature classes with feature writer
  • Oct 27, 2019 10:31 PM UTC
  • 6 replies
  • 341 views
wilczekmj
Forum|alt.badge.img+4
Hello,
I have a workbench that updates metadata by reading a file geodatabase with multiple feature classes. The multiple feature classes will change every time, i.e. in effect I want to update metadata for all feature classes in a file geodatabase based on excel provided for every feature class.
I am reading the file geodatabase with directory and file path reader and then using feature readers for file geodabase and raster dataset. They need to be split as raster dataset has a separate reader.
Then I am updating the metadata for each feature class based on input excel, which works fine.
However, I cannot write the metadata back to the original file geodatabase feature classes using either feature writer in a dynamic way, i.e. write to all feature classes in the file geodatabase or with a dynamic file geodatabase writer.
I am getting errors and I run out of options on how to do it.
This is how I am reading:
And this is how I am trying to write the updated metadata back to file geodatabase only at this time, raster dataset will be added later:
Your help much appreciated.
Magda
itay
Forum|alt.badge.img+19
  • Oct 28, 2019 8:39 AM UTC
Hi @wilczekmj,
How are you recreating the new metadata string? maybe this article can help:
https://knowledge.safe.com/articles/22583/working-with-geodatabase-metadata-writing-to-xml.html
Forum|alt.badge.img+54
  • Oct 28, 2019 9:05 AM UTC
What are the errors you are getting? The most likely cause of error is your xml string not being correct.
wilczekmj
  • Oct 28, 2019 10:11 AM UTC
Hello ebygomm,
Many thanks for looking at this and your help with previews related question:)
The error message I am getting with Feature writer is:
"Attempting to create table 'HYD_871_160_103_00_REF_MainRivers10k_Ln' with 'geodb_type' set to 'geodb_metadata'. FME features of 'geodb_metadata' can only be written to existing tables. If intending to write metadata, please ensure the table already exists. If intending to create a new table, ensure the 'geodb_type' is set to a valid table type.
A fatal error has occurred. Check the logfile above for details"
It looks as it is trying to create rather than update to the existing feature class.
wilczekmj
  • Oct 28, 2019 10:13 AM UTC
Hi @wilczekmj,
Thank you itay. Thank you. I went through this article and metadata manipulation works fine for me. I am dealing with a more complex looping through all feature classes in thegeodatabase to write metadata back to them.
sipsysigh
Forum|alt.badge.img+12
  • Nov 21, 2019 12:12 PM UTC
Hi @wilczekmj,
The error message you quote in your comment suggests that you are trying to write metadata to a feature class that doesn't exist.
If you want to update existing metadata of a feature class then you would need to point your reader and writer to the same geodatabase or, at least during testing, point your writer to a copy of the original geodatabase.
You can set the Table | General parameters of the FeatureWriter to Insert and Use Existing.
You'll also need to make sure that you don't overwrite the existing geodatabase.
Hope this helps,
Si
trentatsafe
Forum|alt.badge.img+7
Hello @wilczekmj,
The current error you are getting is as a result of the Destination geodatabase being different than your source, as mentioned by @sipsysigh. If you add a VariableSetter either before your FeatureReader or just after the Path Reader and set the following parameters:
variable name: pathVariable
value: @Value(path_windows)
After this, your workflow stays the same until just prior to the FeatureWriter. Here if you add a VariableRetriever with the following values:
attribute receiving value = _gdbpath
What the above does allows you to maintain the path_windows attribute(which contains the geodatabase path) through the workflow. You could rework the workflow to maintain that attribute, but a variablesett/retriever will do the same. This _gpdpath would then become the dataset value in your FeatureWriter.
On the writer, I believe if you change the Feature Operation to Insert, I suspect it will over-ride the original metadata feature. Update won't work as it will be unable to find a match based on the geodb_metadata_string, as a result of it being altered in the workspace.
Let me know if that works.
