How to stop a workbench with a Startup Python Script
  • Apr 13, 2016 4:00 PM UTC
  • 5 replies
  • 91 views
I'm trying to write a Python-Script how tested a Published Parameter. If its FALSE it should stop the Workbench.
________________________________
import fme
pw = fme.macroValues['passwort']
if pw == "test":
print("PASSWORT RICHTIG")
else:
print("PASSWORT FALSCH")
Best answer by jdh
Raise an exception.
ex.
raise ValueError('Password incorrect')
jdh
Forum|alt.badge.img+41
  • Apr 13, 2016 4:02 PM UTC
Raise an exception.
ex.
  • Apr 13, 2016 6:56 PM UTC
hey jdh, thx for the answer.
I try it with the ASSERT statement.
And it works!!
FME_BEGIN_PYTHON script returned error on execution.
_____________________________________
import fme
assert pw == "test", "PASSWORT FALSCH"
jdh
  • Apr 13, 2016 7:07 PM UTC
And it works!!
import fme
Assertions are generally used for testing/debugging purposes, but essentially it's a shortcut for
if not (x): raise AssertionError (y)
mark2atsafe
Forum|alt.badge.img+59
The example I have is
import os
if os.path.exists(outputFilename):
    raiseException("The output file already exists - choose a different destination filename.)
See this article for more info
jordimonk
  • Jul 11, 2017 9:44 PM UTC
import os
There needs to be an space between 'raise' and 'Exception' as in:
raise Exception("This is an exception")
