How to split a delimited string with a carriage return to create a stacked list.
  • Jul 25, 2017 10:51 PM UTC
  • 5 replies
  • 533 views
Example:
Input = A:1-100+B:1-300+C:1-600
Output = A:1-100
B:1-300
C:1-600
The output will be stored in a multiline attribute in AutoCAD 2017.
Best answer by takashi
Hi @blehm, you can use the StringReplacer to replace '+' with a carriage return.
  • Mode: Replace Text
  • Text To Replace: +
  • Replacement Text: <enter a carriage return using the Text Editor>
fmelizard
Forum|alt.badge.img+22
  • Jul 25, 2017 11:20 PM UTC
Hi @blehm Use a StringReplacer. For the Replacement Text, open the Text Editor and insert a Carriage return from the list of Special Characters.
  • Jul 25, 2017 11:21 PM UTC
  • Jul 26, 2017 4:13 PM UTC
I can replace the delimiter but I'm still not getting the carriage return. see attached
  • Jul 26, 2017 8:28 PM UTC
I figured out what I was doing wrong, I moved the stringreplacer to the output side of my dwgstyler and it works like a charm!
  • Sep 12, 2022 9:02 PM UTC
THANK YOU for this!!! :-)
