How to set user parameter value in workflow?
  • Feb 14, 2018 2:48 PM UTC
  • 7 replies
  • 911 views
I created some user parameters and want to set their values programmatically some time later (when some data is processed). Is this possible? Or I must set their values initially?
Best answer by takashi
FME configures user parameters before starting the translation, and their values cannot be changed in the workflow later.
  • Feb 14, 2018 2:56 PM UTC
  • Feb 14, 2018 3:53 PM UTC
Could always break the workbench into two.
One bit is creating the parameters which then is to be passed into the 2nd workbench using the workbench runner
lau
Forum|alt.badge.img+3
  • Feb 14, 2018 3:58 PM UTC
You can work with 2 workspaces. The first one ("The Controler") will be used to set the parameters of the other(s) workspace(s) ("The worker(s)") based on what you want. To trigger a worker, use the WorkspaceRunner transformer in the controler
jneujens
  • Feb 15, 2018 11:29 AM UTC
I fully agree. The function of a parameter is that you simply give it a value for the entire process.
You can work with attribute values instead of parameters if you want to make it more dynamic?
  • Aug 22, 2019 6:23 PM UTC
Any Ideas, for this related on one?
  • Aug 23, 2019 11:56 AM UTC
user parameters appear they can be deleted tho
gio
Forum|alt.badge.img+15
  • Aug 23, 2019 3:00 PM UTC
@tforward no they cannot be deleted during runtime (in this aplication at least and afaik)
(You can fiddle and add some code to actually do that no doubt.)
@theodolite3
But another possibility is to use environment variables, you can set and read them using fme.
I use that to create user variables by fme and have some batch file proces stuff or and visa versa.
