How to set the reader source URL dynamicaly
  • August 6, 2019
  • 20 views
I need to read a GeoJson from an URL. One of the attributes of the call is the current time that I could get using the "Date/Time Functions" on Text Editor, however those functions are note available in the reader.
I tried to use a FeatureReader where I can set the current time properly but then I don't have the "Network Authentication" options under parameters.
Any clue on how to set the reader source GeoJSON URL dynamicaly?
Best answer by ebygomm
You could use a scripted private parameter for the reader source,  something like this where 'url' is a parameter that contains the fixed part of the url
from time import strftime
return FME_MacroValues['url']+strftime("%Y%m%d-%H%M%S")
Forum|alt.badge.img+46
  • August 6, 2019
  • August 6, 2019
Thank you so much. Exactly what I needed.
