How to select a folder within the folder path to use as an attribute
  • Apr 7, 2017 3:14 PM UTC
  • 8 replies
  • 388 views
I have used the FilenamePartExtractor many times with good results. It is very helpful to be able to pass the root folder of the data to other transformers. I have a similar requirement for a workspace, however in this example I wish to use the folder above the root folder as they attribute.
For example, if I am reading the Source data from this path
C:\\WINNT\\Profiles\\user\\Desktop\\roads.shpI wish to use the 'user' folder to fanout the Writer to create an output folder 'user'. I will then fanout by fme_basename to create the roads.shp within that 'user' folder.In this instance the FilenamePartExtractor does not work as it it does not cater for anything above the Folder Name/_dirname = 'Desktop'
Can someone help me out to extract the 'user' component of the file path so it can be used as an Attribute Value for Fanout?ThanksAndrew
todd_davis
Forum|alt.badge.img+23
  • Apr 10, 2017 3:03 AM UTC
Well you can write a number of things to do it, but just use another FileNamePathExtractor after the first one and set the input attribute as _dirpath. Then you will get what you want out of the output
itay
Forum|alt.badge.img+19
  • Apr 10, 2017 7:01 AM UTC
I would use the Directory and File Pathnames Reader and extract the infomation out of the path returned.
  • May 2, 2017 8:02 AM UTC
Another possible approach: split the source file path with an AttributeSplitter (Delimiter: \\), then extract the third element from the last of the resulting list with a ListIndexcer (List Index: -3).
  • May 2, 2017 8:07 AM UTC
Agreed, just be careful because it won't work on Linux or Mac.
  • May 2, 2017 8:24 AM UTC
Thanks for the point, @david_r.
If the workspace should be run on any platform including both Windows and UNIX, replace every backslash \\ with slash / beforehand, and then use the slash as delimiter in the AttributeSplitter.
Windows considers both backslash and slash as path delimiter, but UNIX only allows to use slash as path delimiter. I therefore prefer to use the slash, usually.
  • May 2, 2017 8:36 AM UTC
If the workspace should be run on any platform including both Windows and UNIX, replace every backslash \ with slash / beforehand, and then use the slash as delimiter in the AttributeSplitter.
I agree, paths can be surprisingly complicated. Here's an example that I often see on FME Server instances:
D:/apps/FMEServerRepository///resources/logs/engine/current/jobs\1000\job_1128.log
Notice the mix of forward and backward slashes, as well as duplicate slashes =)
  • May 22, 2017 5:50 AM UTC
Thanks Todd, your solution is simple and effective, I couldn't see at the time that this approach would work!
  • May 22, 2017 5:51 AM UTC
Thanks takashi, this is a very helpful option!
