How to populate attribute with last element from a list?
nicholas
Forum|alt.badge.img+13
Hello all,
I have 1721 point features, which I am combining into a single line using LineBuilder.
Each node has a datetime stamp, and I want to populate the line with the attributes "start_date" and "end_date" drawn from the "date" attribute of the first and last point feature.
In the LineBuilder I have ticked the parameter Generate List, so I have a list with 1721 elements.
I can use the Attribute manager to create a new attribute "start_date" with a value of;
@Value(points{0}.date)
However, I fail to do the equivalent for the last element in the list.
@Value(points{-1}.date) is not accepted by the Text editor or the List Element Selection: points{}.date
I thought I might solve it by using ListElementCounter, which does create a new attribute with a value of 1721, but again the List Element Selection: does not accept an attribute value as an input.
Best answer by nicholas
Thanks @deanhowell2009, I checked out that post, and chose the ListIndexer, which does allow a value of -1 for the list index.
Note: my list is points{} with a single attribute "date" and 1721 elements.
List Attribute: points{}
List Index to Copy: -1
Copied Attribute Prefix: end_
The end result was a new attribute of "end_date" populated with the value from the last element in the list. This is exactly the result I am looking for :-)
I also did a second ListIndexer to grab the start_date
deanhowell
Forum|alt.badge.img+23
  • August 26, 2019
nicholas
  • August 26, 2019
