How to populate a field with a value from a specific field identified in another field
  • May 11, 2018 8:19 PM UTC
  • 338 views
dvanriel
Forum|alt.badge.img+9
I am trying to populate a new field with a value from another field. It is not a simple attribute copy. Each record is getting the value from a different field that is specified in another field.
For example: I have the table below and I want to populate NEW_FIELD with one of the values of fields FIELD1 through FIELD4 based on what is provided in FIELD_TO_USE. This has to be dynamic (no hard coded TestFilter as I am doing that now).
FIELD1FIELD2FIELD3FIELD4FIELD_TO_USENEW_FIELD1234FIELD115678FIELD26ABCDFIELD3CEFGHFIELD4H
erik_jan
Forum|alt.badge.img+26
  • May 11, 2018 8:23 PM UTC
AttributeCreator with:
New attribute NEW_FIELD
Value @Value(@Value(FIELD_TO_USE))
  • May 11, 2018 9:55 PM UTC
Alternatively, the AttributeDereferencer could also be used here.
dvanriel
  • May 14, 2018 1:33 PM UTC
Thanks Erik!
dvanriel
  • May 14, 2018 1:35 PM UTC
Thanks Takashi. I don't know which method I will use. They are both one transformer.
It feels like I learn a new transformer every week.
