How to pass a published parameter into a custom transformer
  • Oct 12, 2018 10:17 AM UTC
  • 181 views
How can I pass a published parameter in a workspace into a custom transformer within the same workspace? I think you can pass a publishedParameter into an attribute and then make this attribute available in the custom transformer, just wondered if there was a simple cleaner way?
  • Oct 12, 2018 10:39 AM UTC
Hi @saqibamin, you can create a published parameter in the custom transformer definition with the same way to create a published parameter in the workspace. The published parameter defined in the custom transformer will appear in the transformer GUI as a new parameter for the transformer.
You can then pass the published parameter directly to the custom transformer via the new parameter.
albinepro
Forum|alt.badge.img+7
  • Jan 17, 2023 12:03 PM UTC
I had the same issue, late I've found that you have to unchceck "Disable Attribute Assignment" in user parameters management of Custom transformer workspace (see image). Later zou can assign this parameter to "global" user parameters in the main workspace.
 user_par
