How to merge multiple records but create a list from one attribute?
  • December 6, 2018
  • 210 views
I have 2 records with identical attribute values except for one field (FeatureID). How can I merge the records but create a list from the FeatureID.
The result should be highlighted on the attached picture
chrisatsafe
  • December 6, 2018
Hi @mariofederis,
Have you tried using the AttributeCombiner available on the FME Hub? This transformer will allow you to group by InspectionID, combine by FeatureID, and choose the delimiter string.
attributecombiner.fmw
erik_jan
Forum|alt.badge.img+18
  • December 6, 2018
The Aggregator transformer could do this (Group by InspectionId, Attribute to concatenate FeatureId):
Thanks for the recommendation Erik.
On the same note, my workflow requires me to regain those two features later down the road. How do you recommend I explode them from that 1 record?
Forum|alt.badge.img+38
  • December 6, 2018
If you generate a list in the aggregator with the InspectionID and the Description you'll be able to explode that list to regain the two features.
