How to get the Current Working Folder
sussexpete
Forum|alt.badge.img+4
Hi.
I want to include the name of the "current working folder" (e.g. H:\\00-Data\\FME\\PlanningSitesForGIS) in the body of an emailer so that the recipient can see where a workspace has been run from.
I am using the FME_MF_DIR parameter to do this but as it is listed separately from "current working folder" in the log, wonder if this is correct?
I would also like to know if the parameters FME_MF_NAME and WORKSPACE_NAME are one and the same?
Many thanks for any help
Best answer by redgeographics
FME_MF_DIR refers to the directory the current workspace is stored in, so yes, I'd say that's the one you're after.
FME_MF_NAME and WORKSPACE_NAME differ in that the FME_MF_NAME is the filename of the current workspace, the WORKSPACE_NAME omits the .fmw part
Forum|alt.badge.img+50
  • August 22, 2017
sussexpete
  • August 22, 2017
Many thanks redgeographics. I've included a line which works in my emailer:
FME Workspace has run: $(WORKSPACE_NAME) from $(FME_MF_DIR)
