How to explode a feature to multiple attribute
  • Nov 30, 2019 6:38 PM UTC
  • 5 replies
  • 341 views
Hello;
I collected all of my data into a single feature how can I separate and put them to put in other attributes?
Thanks
  • Nov 30, 2019 10:44 PM UTC
The solution would depend on how the feature has the data (multiple values). If the data were stored in a list attribute, for example you could explode the feature with the ListExploder easily.
  • Nov 30, 2019 11:33 PM UTC
Hi Takashi;
I attached a sample of excel file that I have and need to separate all comma delimited values between all other attributes
Thanks
sheet1sample.csv
  • Dec 1, 2019 7:29 AM UTC
If I understood your requirement correctly, this workflow might help you. The NumToAlphaConverter is a custom transformer from FME Hub. See also the workspace example: csv22none.fmwt (FME 2019.2)
  • Dec 2, 2019 5:46 PM UTC
Thanks Takashi
\\Would you mind send me the result that you got?
  • Dec 2, 2019 6:05 PM UTC
I got it Everything worked Appreciate Takashi
