How to divide number to sequenced list?
  • Dec 12, 2017 8:27 AM UTC
  • 6 replies
  • 80 views
lazarlubomir
Forum|alt.badge.img+11
Hello everyone,
I try to solve problem with numbers and values. In my project, I manage SQL select count via SQL Executor, so the result of query could be for example number 5. But what I need in second step, I have to create list with minimal value 0 and maximum value (result of query) 5. So list will contain following values 0,1,2,3,4 and 5.
Any tips please?
Thank You so much!
Lubo
Best answer by david_r
The "obvious" solution would be to use a Cloner with your query result as number of copies, followed by a ListBuilder.
You can also accomplish the same thing using Python, it is probably also more efficient, performance-wise:
import fmeobjects
def generate_list(feature):
    items_to_create = int(feature.getAttribute('count') or 0) + 1
    items = [''] * items_to_create
    feature.setAttribute('list{}', items)
You need to supply an attribute "count" and it will return a list called "list{}" with count+1 elements containing an empty string, e.g. for count = 5:
`list{0}' has value `'
`list{1}' has value `'
`list{2}' has value `'
`list{3}' has value `'
`list{4}' has value `'
`list{5}' has value `'
  • Dec 12, 2017 8:38 AM UTC
import fmeobjects
lazarlubomir
  • Dec 12, 2017 1:09 PM UTC
import fmeobjects
Yes, it works :-) But how can I fill values for every element of list?
For example:
  1. `list{0}' has value 0
  2. `list{1}' has value 1
  3. `list{2}' has value 2
  4. `list{3}' has value 3
  5. `list{4}' has value 4
  6. `list{5}' has value 5
Thank You so much!
  • Dec 12, 2017 1:32 PM UTC
For example:
Thank You so much!
For example:
import fmeobjects
    for n in range(items_to_create):
        feature.setAttribute('list{%s}' % n, n)
  • Dec 13, 2017 2:54 PM UTC
Interestingly the XMLXQueryExtractor with this XQuery expression works as well. Just for your information.
fme:set-list-attribute("list{}", (0 to xs:integer(fme:get-attribute("count"))))
# I personally call this transformer "XQueryCaller".
  • Dec 13, 2017 2:58 PM UTC
That's an interesting hack. Guess you could call that one the XQueryListPopulator
lazarlubomir
  • Dec 15, 2017 2:41 PM UTC
Great tip @takashi! It works too and probably it is more suitable solution!
