How to detect missing values dynamically using PythonCaller?
  • Jun 27, 2019 4:36 PM UTC
  • 11 replies
  • 197 views
dataninja
I am trying to create a custom tool to help me do QA better and faster.
I have no problem detecting columns with null, empty ... etc but I really struggle to do so with <missing> values in PythonCaller.
Thanks for your help in advance.
Forum|alt.badge.img+54
  • Jun 27, 2019 4:49 PM UTC
Do you have a list of attribute names that you are looking for?
dataninja
  • Jun 27, 2019 4:52 PM UTC
Yes, I use the following function to do so.
Attribute_Names = feature.getAllAttributeNames()
jdh
Forum|alt.badge.img+41
  • Jun 27, 2019 5:36 PM UTC
You would need to have a reference schema, ie all the attributes that should be present.
If you bring that in to the python caller as a list (either reading an external file, or a list attribute)
You can then use
list(set(feature.getAllAttributeNames()).difference(schema_list))
dataninja
  • Jun 27, 2019 5:44 PM UTC
You can then use
Thanks, I will give that a try!
  • Jun 27, 2019 6:15 PM UTC
This will only give you the names of the attributes on the feature. You'll need a list of the attributes you are expecting to have to work out which ones are missing from the feature.
dataninja
  • Jun 27, 2019 7:26 PM UTC
You can then use
What is schema_list? I keep getting this error - Python Exception <NameError>: global name 'schema_list' is not defined.
jdh
  • Jun 27, 2019 7:31 PM UTC
schema_list is a placeholder variable.
In order to know what attributes are missing, you need to know what attributes should be present.
That can be hardcoded into the workspace, or preferably come from an external file.
  • Jun 27, 2019 7:35 PM UTC
You can also use the FMEFeature.getAttributeNullMissingAndType() method:
isnull, ismissing, attr_type = feature.getAttributeNullMissingAndType('my_attr')
This will let know know the disctinction between a missing attribute and a null value.
dataninja
  • Jun 27, 2019 7:46 PM UTC
Hi David, the function works great when I do one attribute at a time:
But it doesn't seem to work properly when I do it through a for loop:0684Q00000ArMG1QAN.png
Do you see anything wrong with my for loop?
jdh
  • Jun 27, 2019 7:49 PM UTC
the getAllAttributeNames() only returns attributes present on the feature. If 'Column 3' isn't present, it's never going to be checked in your loop.
That is why you need a list of all the attributes you want to validate.
dataninja
  • Jun 27, 2019 8:46 PM UTC
Oh I see, is there another solution to get all attribute names to use for the function then?
