How to Call a SystemCaller based on Selected User Parameters
  • July 12, 2024
  • 119 views
bhk
Forum|alt.badge.img+3
I have a script that is supposed to run some .bat files base on calling defined SystemCallers. I have 3 System caller as
each for DEV, HUB, and PROD environments. and I want to control which to run with User Parameters as below
Can you please let me know how I can control which SystemCaller to run based on user selection (For example: if user select the DEV then only the SystemCaller-DEV)
Best answer by nielsgerrits
Creator to initiate.
TestFilter to test if the parameter is dev, uat or prod.
Connect SystemCaller to corresponding outputport of the TestFilter.
nielsgerrits
Forum|alt.badge.img+64
  • July 12, 2024
