How to aggregate list of coordinates
  • Nov 5, 2018 10:39 PM UTC
  • 10 replies
  • 87 views
Hello, I have these records
NoticeNr Coordinate ListID
1130 56-41N 1
1130 56-30N 2
1130 001-57W 3
1130 001-29W 4
1134 52-15.0N 002-30.5E
I would like to aggregate the NoticeNr 1130 to two records having the following coordinates (56-41N 001-57W ) and (56-30N 001-29W). The goal is to have it as NoticeNr 1134, so the order (Listid asc) of lat long values in the table should be respected. What is the best way to do so? It is also possible that there are more than two records for longitude and latitude.
  • Nov 5, 2018 10:50 PM UTC
To help us to understand the rules more clearly, could you please post another example in a case where there are more than two records?
  • Nov 5, 2018 10:54 PM UTC
And clarify how you can convert (56-41N 001-57W) and (56-30N 001-29W) to "52-15.0N 002-30.5E ".
danilo_fme
Forum|alt.badge.img+58
  • Nov 6, 2018 12:15 AM UTC
Hi @kat
I simulated your case here:
1) Created the xls file
2) Search by word N - StringSearcher and filter
  • Passed = N
  • Failed = W
3) Created a ID_new both output port
4) Joiner by ID_new and group by = NoticeNr
5) Concatenate
Attached the Workspace template FMWT - Workspace_X_Y.fmwt
Thanks,
Danilo
  • Nov 6, 2018 1:18 PM UTC
Hi @kat
  • Passed = N
  • Failed = W
5) Concatenate
Thanks,
Danilo
Thanks Danilo. That's great. The only problem I am having with this is that if I have a second NoticeNr with the same issue e.g.
1130 56-41N 1
1130 56-30N 2
1130 001-57W 3
1130 001-29W 4
1135 26-41N 1
1135 16-30N 2
1135 46-30N 3
1135 003-57W 4
1135 005-29W 5
1135 008-29W 6
How can I use the counter grouped by NoticeId?
  • Nov 6, 2018 1:23 PM UTC
Hello takashi, another example:
the original data:
1130 56-41N 1
1130 56-30N 2
1130 001-57W 3
1130 001-29W 4
1135 26-41N 1
1135 16-30N 2
1135 46-30N 3
1135 003-57W 4
1135 005-29W 5
1135 008-29W 6
the output data I would like to have:
NoticeNr Coordinate
1130 56-41N 001-57W
1130 56-30N 001-29W
1135 26-41N 003-57W
1135 16-30N 005-29W
1135 46-30N 008-29W
Is this clear enough ? Or you would like to have more explanations?
  • Nov 6, 2018 1:41 PM UTC
The format of this row is different from others. What's this?
  • Nov 6, 2018 1:45 PM UTC
For all the other records the second value is 0. e.g. 1135 26-41.0N 003-57.0W. I will extract the degrees, minutes, seconds later on and in these case the seconds will be 0. We have different data source and therefore different formats.
  • Nov 6, 2018 2:37 PM UTC
In the original data, why most rows have only have one of latitude or longitude but only the 1134 row has both latitude and longitude?
Do you just ignore such an exceptional row?
  • Nov 6, 2018 3:12 PM UTC
the majority of notices has lat and long in the same row, but there are some exceptions where the lat and lot are in diff rows.
danilo_fme
  • Nov 6, 2018 5:32 PM UTC
Hi @kat
Thanks your feedback. I revised the Workspace with the new Reader Structure like you wrote us above.
Attached the Workspace template - Workspace_X_Y_Update.fmwt
Thanks,
Danilo
