How to access the output of the generated list in the ListBasedFeatureMerger
  • August 14, 2019
  • 25 views
I have a ListBasedFeatureMerger to merge requestors that have IDs that potentially match the ID of the supplier features.
I understand that a list can be generated if there is no complete match with all IDs of the requestor list.
In my case, the generated list "_all_matches" appears in the result on the UnmergedRequestor port (see screenshot 2, it has two entries).
However, I cannot access these attributes with any transformer.
How can I get access to them?
erik_jan
Forum|alt.badge.img+26
  • August 14, 2019
Can it be that the list is not exposed?
Have you tried using the AttributeExposer, exposing _all_matches{}?
Hope this helps.
  • August 15, 2019
Hope this helps.
Yes, but it does not show up there.
  • August 15, 2019
The solution apparently is to name the generated list in the ListBasedFeatureMerger the same as the existing list of the requestor features – in this case the name has to be
_matches
