How do I use a JSON element as attribute value?
  • November 12, 2020
  • 8 replies
  • 345 views
I have a JSON file, structured like this:
  "W-Number": {
    "EP1": [
        "timestamp": 1407859200000,
        "value": 1.35
        "timestamp": 1407862800000,
        "value": 1.44
    "EP2": [
        "value": 1.58
        "value": 1.63
I want to turn it into a table, like this
W-Number | timestamp | value
EP1 | 1407859200000 | 1.35
EP1 | 1407862800000 | 1.44
EP2 | 1407859200000 | 1.58
EP2 | 1407862800000 | 1.63
What I managed so far: used JSONFlattener, then AttributeExposer to expose (see below*). Then I used a ListExploder; it works when I specify e.g. W-Number-EP1{}, which gives me a table for the timestamp and value of EP1, however I require a single Table for all EP's that might exist, without exploding the list for each manually. Would that be possible somehow?
exposed
Best answer by ebygomm
I'd use a JSON fragmenter to break into EP fragments then a list exploder
CaptureCapture
  • November 12, 2020
Here's one way using two JSONFragmenters in parallel:
jsonfragmenterYou'll maybe want to add e.g. an AttributeCreator after each JSONFragmenter to identify if each line is from EP1 or EP2.
Yes, but would basically have the same effect as using a bunch of ListExploders, which would also require manually inserting one for each "EP". I'd kinda need something like.. ["W-Number"]["EP"[*]][*]?
Forum|alt.badge.img+38
  • November 12, 2020
CaptureCapture
jdh
Forum|alt.badge.img+28
  • November 12, 2020
It can probably be done in xquery using the XMLXQueryExtractor, however I dropped into python instead.
import json
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        j = json.loads(feature.getAttribute('json'))
        w = j["W-Number"]
        for k,v in w.items():
            feature.setAttribute("W-Number",k)
            for x in v:
                for l,m in x.items():
                    feature.setAttribute(l,m)
                self.pyoutput(feature)
    def close(self):
        pass
jdh
  • November 12, 2020
CaptureCapture
For some reason when I originally tried this, the JSONFragmenter rejected the feature.
Trying it again, it's now working, and the best solution. All you need to do afterwards is rename the json_index attribute to W-Number.
  • November 13, 2020
I don't understand the comparison with ListExploders. I understand wanting to avoid them, as they are very slow if you have lots of data, but the JSONFragmenter should be much faster.
CaptureCapture
Wonderful, this got rid of the JSONFlattener and AttributeExposer as well 👍
The output (and effort to make/edit the workspace) would be the same. I got kinda stuck trying to use the AttributeExposer output, but it wasn't even necessary in the end (see the other answer).
