How do I set format attributes for a feature type to go into a bentley V8 .dgn or an AutoCAD .dwg file?
  • Jan 11, 2016 5:12 PM UTC
  • 75 views
gmbutler2
Forum|alt.badge.img+10
I am trying to set formatting for a feature type to change into a microstation dgn file, but I can not figure it out. Please help!
erik_jan
Forum|alt.badge.img+26
  • Jan 11, 2016 5:18 PM UTC
The easiest way is using the DGNStyler transformer for MicroStation and DWGStyler for AutoCAD.
It has a lot of options to set pre-defined format attributes for different types of features.
gmbutler2
  • Jan 11, 2016 5:42 PM UTC
OK! What you have to add is a DGNStyler and that allows you to format your output.
gmbutler2
  • Jan 11, 2016 5:43 PM UTC
Thanks erik_jan. That is a big help. I found the dgnstyler but knowing there is a dwgstyler as well is a life saver. That does everything I need. Hopefully I can get the cells to work with my data. Thanks again!
