how could i combine two excel files in one excel file as seprated sheets
  • Mar 9, 2020 5:40 PM UTC
  • 6 replies
  • 323 views
gogopotter90
Forum|alt.badge.img+14
i have two excel writer but i want to have one excel output has both of them as seperated sheet so i used fme_feature type
but it still give me output as two excel file , i do not know why
i used attribute creator then attribute filter
to get two seperated sheet but it does not work with me
i used sheet name @Value(fme_feature_type)
and also edit parameter fan out and overwriting yes
First excel writer :
because i have many seperated tables so i used
output field name NO
USE ATTRIBUTES NAMES AS COLUMN POSITION YES
i have A B C D AND SO ON NAME OF COLUMNS so my question should i used attribute creator for fme_feature_type before connects to excel writer direct and so excel writer will recognize fme_feature_type or should i enter it in each table that i divided
i tried both of this metthod but i did not get my expected output
second excel file
utput field names yes and use attribute names as column position no
whatever i did not have many tables in this excel sheet so i do not want to use the column posiiton
but my question now how could i make both of them in one excel file as two seperated sheets and with the name of fme feature type .
could someone help me to put two excel files in one excel file but separated sheet
FME VERSION 2018
Thanks alot
  • Mar 9, 2020 7:03 PM UTC
Instead of using the old writers, try using a FeatureWriter. You can then pull your connections to the "Connect Input" input of the FeatureWriter and each connected input will become a separate sheet inside the FeatureWriter.
Try it for yourself, it's quite self explanatory and I'm sure you'll be satisfied. :-)
gogopotter90
  • Mar 10, 2020 2:01 PM UTC
thanks for ur suggestion it is working perfect but i tried to use attribute to make the output excel file name as attribute it does give me any output.
could u tell me how could i rename the excel output file depends on attribute and also i want to add date beside the name .i tried using fme_feature_type as attribute name but it gives me nothing
  • Mar 10, 2020 3:32 PM UTC
In the dialog for the FeatureWriter, click the down-arrow to the right of the Dataset field and select Open Text Editor.
In the text editor you can find all your attributes in the list on the left, under FME Feature Attributes. If you have defined your filename as an attribute, this is where you can pick it by double-clicking it.
And then you can scroll down to Date/Time Functions (still in the text editor) and double-click DateTimeNow and add ".xlsx" at the end to get a filename that looks like this:
@Value(<your_filename>)@DateTimeNow().xlsx
That's just a simple way to do it. By using transformers, e.g. the AttributeCreator, you can shape your filename exactly as you want it as an attribute, by using string functions and date formatters, and then use that as filename in the FeatureWriter.
gogopotter90
  • Mar 10, 2020 4:46 PM UTC
could u provide small workspace include two sheet one with seperated tables has empty rows and one without ,and the important for me how to create name and date of excel file .bcs i spent many hours on that but no success.Thansk alot
  • Mar 11, 2020 12:00 PM UTC
When you use a filename consisting of an attribute value and/or for example a timestamp, it is important that the resulting file name is the same for both sheets. So in the attached example I have formatted the timestamp to year/month/date, otherwise, since the two inputs have timestamps that differ by some seconds, they would generate two files instead of two sheets.
Hope this helps!
spreading_sheets.fmw
gogopotter90
  • Mar 11, 2020 3:34 PM UTC
Thanks alot it is working perfect nw
