How can I use the string "$()" in a parameter or feature attribute?
  • May 29, 2017 4:13 PM UTC
  • 130 views
chk1
Forum|alt.badge.img+7
I'm trying to use a string that contains
 (dollar, left parenthesis, right paranthesis) via a published parameter in a HTTPCaller.
I'm having trouble using a text/string like that because, depending on the transformers used,
  • either the part "$()" simply disappears, or
  • FME throws an error: "Undefined macro `' dereferenced"
I tried to create a feature using the PythonCreator and also Creator + AttributeCreator, however both fail with the error mentioned above. Screenshot of my test workspace:
I thought about escaping the string but that didn't work either (no error, but backslashes "\" remain in the text):
What is the right encoding or escaping sequence here?
I tested FME Desktop 2015.1 and 2016.0.
erik_jan
Forum|alt.badge.img+26
  • May 29, 2017 5:08 PM UTC
This worked (but is not the nicest solution):
  • May 29, 2017 5:37 PM UTC
Hi @chk1, try changing the parameter type to Text (Mutiline).
  • May 30, 2017 2:58 AM UTC
oops, the workaround using Text (Multiline) type parameter seems to be available in FME 2016.1 or later. In 2016.0 and earlier, a Text (Multiline) type parameter causes the error too...
