how can I read points that created curve in dwg
  • Feb 18, 2025 8:19 AM UTC
  • 105 views
mkh.rcjy
Good morning,
I want to read the points the created the curve in DWG civil 3D file
so the reader will draw the  curve with the same accuracy.
koulsoum
Forum|alt.badge.img+14
  • Feb 18, 2025 10:23 AM UTC
Hi ​@mkh.rcjy ,
I would say a Transformer Chopper with maximum vertices = 1, will gives you points of the curve.
hkingsbury
Forum|alt.badge.img+73
  • Feb 19, 2025 8:54 PM UTC
In addition to the above, the ArcStroker and ArcEstimator are helpful when deal with Arcs (Curves)
The ArcStroker will convert the Arc to a polyline, and the ArcEstimator essentially does the opposite - takes a polyline and estimates an Arc that fits
http://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/arcstroker.htm
http://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/arcestimator.htm
