How can I force a workspacerunner to output through the failed port?
  • November 11, 2015
  • 29 views
I have a workspace that is run from a workspace runner, the final thing it does is fire off a soap message to a web service, as long as it gets a response it determines the workspace to have been a success. I want to look at the response and if it isn't what I was expecting I want the workbench to output through the failed port of the workspace runner. I am hoping there is some kind of flag on the workspace that I can change to cause it to output through the fail port?
Any help much appreciated
Regards
Jim
Best answer by sigtill
Use the Terminator
sigtill
Forum|alt.badge.img+25
  • November 11, 2015
Use the Terminator
sigtill
  • November 11, 2015
Or a PythonCaller to terminate as described here https://knowledge.safe.com/questions/4957/python-startup-script-to-terminate-workspace.html
