How can I assign GIS Attribute field types in FME Attributes while converting.
  • Jan 10, 2022 5:46 AM UTC
  • 68 views
chithramc
Participant
Forum|alt.badge.img+4
Hello Friends,
I'm new to FME.
While Im converting ROAD_NAMEE given as character, after conversion its came as string in GIS. how can I get the same?
PS. Converted from dgn to shp. dgn file elements are attached with tag.
please help someone
Thanks
ForumSequence numbers1Road_Name_FME1Road_Name_GIS
itsmatt
Forum|alt.badge.img+48
  • Jan 10, 2022 7:30 AM UTC
In FME 'char' is the same as String - it's just a different name.
You can see a list of the different types which FME supports here for attributes: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/!FeatureTypeProperties/FME-Data-Types.htm
The writers usually have a sub-set of this list based on what the output/input format supports. There is some more format specific info here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/shapefile/user-attributes.htm
