Handling caching in 2020 ?
  • Apr 2, 2020 8:02 AM UTC
  • 89 views
lifalin2016
Forum|alt.badge.img+42
Hi.
First let me say, that I absolutely love the incremental run abilities added to 2020. It makes incremental building and debugging workspace a breaze.
However, production runs are a different matter. Here one always runs the full workspace and as fast as possible. I.e. no caching.
I often utilize a master-slave workspace setup, where one workspace calls other workspaces as needed.
Now, the caching is a Workbench setting, and cannot be set for a workspace, but does it only apply to the master workspace being run directly, or does it also apply to the initiated workspace that are called by the master workspace ?
Cheers.
itsmatt
Forum|alt.badge.img+48
  • Apr 2, 2020 8:18 AM UTC
Na it will only apply to the process called by the worksapce opened in FME Workbench. Plus you can turn it off
lifalin2016
  • Apr 2, 2020 8:29 AM UTC
Feature caching in the master workspace is often of lesser concern, than feature caching in the typically heavier slave workspaces. I hope you're right.
itsmatt
  • Apr 2, 2020 10:59 AM UTC
FME 2019 and FME 2018 also had feature caching and partial runs and it didn't effect production. Jobs on FME Server also are not effected by feature caching.
mark2atsafe
Forum|alt.badge.img+59
I'm 99.9999% sure that you only get caching when the workspace is open in Workbench. But you could easily check the log file for the second workspace, and see what it says. You'd get lines like this:
Stored x feature(s) to FME feature store file `C:\Users\mark\AppData\Local\Temp\wb-cache--RMnOhj
...if caching were happening.
