Grouping on average
  • Oct 17, 2016 12:47 PM UTC
  • 31 views
tva
Forum|alt.badge.img+13
I'm having difficulties with the following problem:
I'm having X polygons (with unique ID)(lets assume 1000 polygons) and Y points inside those polygons. First I do colorsetter so see which polygons are disconnected. So I have X polygons with an attribute _color (with 5 different possible values). Then I use spatial overlay to know which points are inside a certain polygon and in the end I'm using a statistics calculator to count the amount of points inside the polygon. As end result I have X polygons with as attributes: unique ID, _color and count of points.
Now I want to split these X polygons into Z groups (public parameter, let's assume 10), but in a way that these 10 groups contain sort or less the same amount of points.
Does anyone has some ideas to group them on an average? I don't mind the amount of polygons in a group. ex group 1 can contain only 1 polygon (as it contains a lot of points) while rest of the group can contain 11 polygons.
Thanks
VAT
itay
Forum|alt.badge.img+19
  • Oct 18, 2016 6:18 AM UTC
Hi @vat, I have added a workspace that groups based on created features and data.
Hope this helps.
grouping-on-average.fmw
