group by
  • Feb 26, 2020 12:25 PM UTC
  • 78 views
HEllo,
I want to create an attribute (distance) between two points. I am using AttributeCreator to do it. Here is the code:
@Evaluate(@sqrt((@Value(feature[+1].y)-@Value(y))*(@Value(feature[+1].y)-@Value(y))/(@Value(feature[+1].x)-@Value(x))*(@Value(feature[+1].x)-@Value(x))))
The problem is that I want to calculate it only between points where lineID is the same. How can I add a kind of group by?
Thanks
Forum|alt.badge.img+54
  • Feb 26, 2020 12:29 PM UTC
You can use a conditional statement in the attributecreator, if @Value(LineID) = @Value(feature[+1].LineID) use the above expression, if not do nothing
@gylona or perhaps try the NeighborFinder?
