GoogleBigQueryConnector Failed to Authenticate
  • Oct 31, 2024 4:11 PM UTC
  • 5 replies
  • 225 views
rzel24
Forum|alt.badge.img+7
Hello,
I’m having a hard time figuring out why a json file created with a Text Writer is not accepted by the GoogleBigQueryConnector.
I have an original JSON Key File downloaded from Google Cloud for the Service Account we are using to authenticate to BigQuery. This JSON file works fine and I am able to authenticate and select the Dataset I want to upload data as well as the table in that Dataset.
The problem is that since I have to use a system environment variable and specify the service account key file location in that variable in order for the GoogleBigQueryConnector to be able to use Service Account instead of Web Connection, it seems the GBQC takes the project_id specified inside that json file and uses it as default project to log you in, which means that even if you have access to different projects in BigQuery you can only access 1 project per Service Account Key File.
Here is an image of the error I get for when the GBQC tries to use the JSON file to authenticate into BigQuery:
Here is the text with the Details that it shows (can’t really make head or tail of why is not accepting the file as a JSON file:
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\auth\_default.py:102)
load_credentials_from_file
    info = json.load(file_obj)
(json\__init__.py:293)
load
(json\__init__.py:346)
loads
(json\decoder.py:337)
decode
(json\decoder.py:355)
raw_decode
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\fmepy_google_bigquery\auth.py:33)
get_client
    return client(client_info=get_client_info(), _http=session, **credentials)
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\cloud\bigquery\client.py:174)
__init__
    super(Client, self).__init__(
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\cloud\client.py:249)
__init__
    _ClientProjectMixin.__init__(self, project=project)
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\cloud\client.py:201)
__init__
    project = self._determine_default(project)
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\cloud\client.py:216)
_determine_default
    return _determine_default_project(project)
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\cloud\_helpers.py:186)
    _, project = google.auth.default()
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\auth\_default.py:338)
default
    credentials, project_id = checker()
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\auth\_default.py:185)
_get_explicit_environ_credentials
    credentials, project_id = load_credentials_from_file(
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\google\auth\_default.py:107)
    six.raise_from(new_exc, caught_exc)
(<string>:3)
raise_from
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\fmepy_google_bigquery\resource_selector.py:70)
getContainerContents
    api = GoogleBigQueryApi(get_client_credentials_dict(options), LOG_NAME)
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\fmepy_google_bigquery\api.py:45)
__init__
    self.client = get_client(bigquery.Client, credentials)  # type: bigquery.Client
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\fmepy_google_bigquery\auth.py:35)
get_client
    raise GoogleBigQueryApiError(
(C:\Users\r.z\AppData\Roaming\Safe Software\FME\Packages\24619-win64\python\safe.google-bigquery\fmepy_google_bigquery\resource_selector.py:72)
    raise WSCException(e.message_number, e.message_parameters)
I’ve tried all the different formats to write the text file (which I intentionally save as .json instead of .txt) but still I can never get the GBQC to accept the file written by the Text Writter transformer as a valid JSON file.
When I compare the original JSON file to the one created by the Text Writer using Notepad++ and show all the characters, I cannot find any difference between the 2:
I’ve tried using a JSONtemplater with JSONFormatter  and then write the JSON file with a text writer but still the end result file is not accepted as a valid json file by the GBQC.
Any idea what I might be doing wrong?
Thanks in advance.
Regards,
RZ.-
  • Nov 1, 2024 10:54 AM UTC
When configuring the Text File writer for JSON output, make sure to use UTF-8 encoding, and also drop the byte-order marker (BOM):
rzel24
  • Nov 1, 2024 11:00 AM UTC
Hi @david_r
Yep I already tried that and I still get the same error message that the file is not a valid json file.
I basically spend several days trying all different settings in the Text Writer and no matter what I used I got the same error and it is driving me nuts as I can seem to figure out why.
Thanks again.
RZ.-
debbiatsafe
Forum|alt.badge.img+24
Hi @rzel24
How is your workspace designed? Our development team suspects you may be running into this issue due to timing. The suspected sequence of events:
  1. The text line writer clears the destination JSON file when it starts up
  2. The Google Big Query connector/writer tries to read the now-empty file and rejects it for being invalid JSON
  3. The writer wraps up by writing the JSON to the destination, so inspection afterwards makes you think that the Connector is rejecting valid JSON
Try either using the Text Line format in a FeatureWriter or an AttributeFileWriter to write the JSON. Then connect the output of the transformer to the Google Big Query transformer or writer. This ensures the contents are saved to disk before the JSON file is read.
rzel24
  • Nov 13, 2024 9:03 AM UTC
Hello @debbiatsafe,
Thanks for the reply, the workspace is configured sequentially, which basically means the GoogleBigQueryConnector is almost at the end of the end of the workspace after the Json file is re-written, I have even separated the work into 2 different workspaces to ensure the writing of the Json file is completed before it is read by the GoogleBigQueryConnector.
Despite all the above the error is still the showing up.
RZ.-
debbiatsafe
Hello ​@rzel24
Are you able to try writing to the JSON service account key file using an AttributeFileWriter instead of the Text File Writer? It would be good to know if using a different method to write also causes the same error. I would recommend setting the If Target File Exists parameter to Overwrite File and the Target File Encoding parameter to UTF-8.
