Give parameter an attribute value
  • Jul 19, 2013 8:56 PM UTC
  • 80 views
Hello,
I would like to know if there is a way to give a published parameter a default value from an attribute?
Thanks,
Gabriel
  • Jul 19, 2013 11:02 PM UTC
Hi Gabriel,
No, we can't change published parameters at run-time unfortunately.
Takashi
  • Jul 20, 2013 6:15 AM UTC
If you have to set a value read from a dataset to a published parameter of the workspace, consider creating another workspace having a WorkspaceRunner. You can pass a value to a published parameter of the main workspace and run it through the WorkspaceRunner.
Takashi
  • Jul 22, 2013 3:35 PM UTC
I belive this will solve my problem, Takashi.
Thanks!
fmelizard
Forum|alt.badge.img+22
  • Aug 23, 2013 6:34 PM UTC
You could try to create an attribute containing the default value and publish it as described in here (see Parameters: Attribute Name Parameter)
