Get a list of filenames based on the user selection?
  • May 6, 2024 9:00 AM UTC
  • 128 views
itsmatt
Forum|alt.badge.img+48
I’m working on an upload process via REST call and I want to use FME to do the upload.
For the API I need to provide a list of file names in advance. I want this to just work and I want to be able to use FME’s multiple file picker to allow the user to pick folders, multipler files or just a single file. etc.
Does anyone have a good/robust method for getting a full list of the files (and filenames) that this input could be.
My initial plan is to split up the input parameter into a list and then figure out what are folders and what are files and for folders I would use a PATH reader to get the files.
I guess I need a “MultiFilePathResolver” kind of thing.
Best answer by hkingsbury
I’d go the way you suggested, figure out what are folders, and then find the files in those folders.
I’d want to set a traversal limit, because if someone selected “C:\” then they’re going to be uploading the entire computer
hkingsbury
Forum|alt.badge.img+73
  • May 6, 2024 8:19 PM UTC
itsmatt
  • May 7, 2024 6:18 AM UTC
Thanks @hkingsbury , and good tip on the limit. Are you speaking from experience…hehe
