GDB writer and python scripted parameter in FME 2019
  • Aug 19, 2019 9:35 AM UTC
  • 8 replies
  • 177 views
nielsgerrits
Forum|alt.badge.img+67
In pre 2019 versions of FME I often used a python scripted parameter to generate a timestamp which I used in the filename of a File Geodatabase.
All I used was:
import datetime
return datetime.datetime.now().strftime("%Y-%m-%d %H-%M-%S")
Now I can't get it to work anymore. The moment I add the parameter the workbench is done:
2019-08-19 11:26:35|   2.1|  0.0|FATAL |GEODATABASE_FILE writer: An unknown exception occurred
I suspect it has something to do with the deprecation of python 2.6? What configuration do I need to set to get this to work?
My Python skills are nonexistent, so it might be something obvious but I can't find what I'm doing wrong.
Best answer by nielsgerrits
Many thanks David, got it to work. (But I still don't understand why, so if anyone understands and want to explain, please!)
For documentation, this is how I got it working:
  • Aug 19, 2019 9:53 AM UTC
Are you sure there's not something else going on? I copy-pasted your code into a new workspace and was not able to reproduce the error.
Can you perhaps post a minimal example here that reproduces the issue?
nielsgerrits
Sure!
scripteddatestampsample.fmw
It writes a file geodatabase, but no featureclass. And log gives only the line with fatal in it.
  • Aug 19, 2019 10:53 AM UTC
Try setting the Python interpreter to the one from ArcGIS, e.g.:
That works for me.
nielsgerrits
That works for me.
If I select "Esri ArcGIS Desktop (Python 2.7)" the log returns:
Starting translation...
A Python interpreter could not be loaded. Please ensure the workspace `Python Compatibility` is set to an available Python version
Program Terminating
Translation FAILED.
I do have ArcMap 10.4.1 and ArcGIS Pro 2.4.1 installed / licensed. I can start both without any issues. I also have Background processing installed, if that matters. I always worked with the default 2.7 interpreter :-) Any idea how I need to get the other one running?
The Python stuff always scares me a bit as I don't have a clue what I am doing.
  • Aug 19, 2019 11:15 AM UTC
Program Terminating
Translation FAILED.
If you have ArcGIS Pro installed, why not go for Python 3?
nielsgerrits
Same issue as the esri interpreter, no matter what I select, it does give the "A Python interpreter could not beloaded. " error.
  • Aug 19, 2019 11:25 AM UTC
Sounds like FME has a hard time locating the correct ArcGIS installation for each scenario. I guess you have to look at the PATH settings and maybe also set PYTHONHOME to point to either interpreter.
nielsgerrits
  • Aug 19, 2019 11:50 AM UTC
