"Any published parameters associated with the server workspace must be given values. These values can be taken from attributes of the feature that triggered the job to be submitted, or can be typed in (in which case they will be the same for each job that is sent via the transformer)."
But I can't seem to find how this is actually done in Workbench. The wizard page lists my published parameters but does not have the usual drop-down arrow to allow me to specify the feature attribute to assign as the value. I also tried setting the value using the macro @Value(attribute_name) but all that did was pass through the string. So is this an error in the docs or am I missing something obvious?
FME Desktop 2013 and FME Server 2013
