FMEServer.init Javascript fails to define server
  • Apr 14, 2020 9:23 PM UTC
  • 10 replies
  • 106 views
fme_noob
Hey Everyone,
I'm trying to do some javascript work with FME Server. I can't seem to connect to my server that runs FME Server. I have the FMEServer.init method set up window.onload but I get the attached error. The onload code is below too, the FMEServer.init portion is near the bottom.
window.onload = function()
debugger;
require([
"esri/map", "esri/toolbars/draw",
"esri/graphic", "esri/geometry/webMercatorUtils",
"esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol",
"dojo/_base/Color", "dojo/dom", "dojo/on", "dojo/domReady!"
], function(
Map, Draw,
Graphic, webMercatorUtils,
SimpleLineSymbol, SimpleFillSymbol,
Color, dom, on
map = new Map("mapDiv",
basemap: "hybrid", //Select the basemap
center: [-155.114166, 70.27], //Enter the coordinates to center the map
zoom: 7, //Set the default zoom
minZoom: 4,//Set the minimum zoom level
smartNavigation: false
map.on("load", function()
toolbar = new Draw(map);
dojo.connect(toolbar, "onDrawEnd", addToMap);
on(dom.byId("draw"), "click", drawPolyline);
on(dom.byId("reset"), "click", drawReset);
function addToMap(geometry)
var symbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_NULL,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0]), 2
new Color([255, 255, 0, 0.25])
geometry = webMercatorUtils.webMercatorToGeographic(geometry);
var graphic = new Graphic(geometry, symbol);
map.graphics.clear();
map.graphics.add(graphic);
toolbar.deactivate(Draw.POLYLINE);
storedGeometry = geometry.paths[0];
function drawPolyline()
drawReset();
toolbar.activate(esri.toolbars.Draw.POLYLINE);
function drawReset()
toolbar.deactivate(esri.toolbars.Draw.POLYLINE);
debugger;
FMEServer.init(
server: "http://hocwapp0053", //Update with your Server hostname - on FME training machines this is http://fmetraining
token: "7a2fce751ef10468fe6952670ccebcaa449edc39" //Update to your fmetoken
siennaatsafe
Forum|alt.badge.img+12
Hi @fme_noob,
In your code somewhere are you initializing the FME JavaScript API?
It should look something like this
<!-- Include FMEServer.js -->
<script type="text/javascript" src="https://api.fmeserver.com/js/v3/FMEServer.js"></script>
fme_noob
  • Apr 15, 2020 7:37 PM UTC
Hi @fme_noob,
Hey @siennaatsafe thanks for the repsonse. I do have that bit in my html head
<head>
<title>Example</title>
<!-- Styles for example -->
<link rel="stylesheet" href="http://playground.fmeserver.com/css/FMEServerExamples.css" type="text/css" />
<!-- The following are Required for ArcGIS Maps -->
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css" />
<script type="text/javascript" src="http://js.arcgis.com/3.8/"></script>
<!-- <script type="text/javascript" src="jquery-3.3.1.js"></script> -->
<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
<script src="Javascript/Alaskajs.js"></script>
</head>
siennaatsafe
<head>
</head>
Hi @fme_noob,
Could you put all your code into something like JS fiddle so I can take a look? https://jsfiddle.net/
fme_noob
  • Apr 15, 2020 8:35 PM UTC
Hi @fme_noob,
@siennaatsafe I've copy/pasted it in jsfiddle. IT partially won't work because my html/js file are in my own folder structure atm: https://jsfiddle.net/cmclellan/8fynkcje/
siennaatsafe
Hi @fme_noob,
When I have your code like this I can get a response back from the Server. https://jsfiddle.net/90jrdgzt/3/
fme_noob
  • Apr 15, 2020 9:18 PM UTC
Hi @fme_noob,
My issue seems to be when I try to replace the server with my own company server thats hosting my FMEServer
You have https://bluesky-safe-software.fmecloud.com/ on line 72 of the javascript but I have to change it to my own. Are there any guidelines to accomplishing this?
siennaatsafe
I think JS fiddle doesn't like servers with http. However, this code on a normal server should work with http or https. How are you hosting your code? Could you try something like the python example here? https://s3.amazonaws.com/gitbook/Server-REST-API-UC20/FMESERVER_RESTAPI8Session2/8.2.HostingWebApplications.html
fme_noob
  • Apr 16, 2020 3:32 PM UTC
Hey @siennaatsafe
Since this is an internal tool at my company, I wasn't sure what if any hosting I needed to perform. Does Safe have any on-prem servers and has anyone tried the FMEServer.init function in that situation?
siennaatsafe
Hey @siennaatsafe
Hi @fme_noob,
I've tested these with the Python server which creates a local web server for testing and it worked for me. https://developer.mozilla.org/en-US/docs/Learn/Common_questions/set_up_a_local_testing_server
fme_noob
  • Apr 16, 2020 7:17 PM UTC
Hi @fme_noob,
Hey @siennaatsafe
So I logged onto my server and used the python method to set up a http://localhost:8000. I ran the html through the local host and for some reason my server is still undefined on the init function.
