fmeobjects.FMECoordSysManager() not working in defining a coordinate system in FME 2024.
  • Feb 9, 2026 2:30 PM UTC
  • 77 views
aguan
Forum|alt.badge.img+11
I dug out one of my old FME 2014 workbenches. It has this PythonCaller defining a local CRS. It had worked beautifully for years.
import pyfme
#define custom CRS
myCSMan = pyfme.FMECoordSysManager()
fmeParams = {}
fmeParams['CS_NAME'] = "local_polyconic_cs"
fmeParams['DESC_NM'] = "Dynamic CS"
fmeParams['DT_NAME'] = "WGS84"
fmeParams['PROJ'] = "PLYCN"
fmeParams['UNIT'] = "FOOT"
fmeParams['X_OFF'] = 0.0
fmeParams['Y_OFF'] = 0.0
fmeParams['MAP_SCL'] = 1.0
fmeParams['SCL_RED'] = 0.9996
fmeParams['SOURCE'] = "HESS"
fmeParams['QUAD'] = 1
fmeParams['ZERO_X'] = 0.0001
fmeParams['ZERO_Y'] = 0.0001
surf_lat = float(feature.getAttribute('surf_lat'))
surf_long = float(feature.getAttribute('surf_long'))
fmeParams['PARM1'] = str(surf_long)
fmeParams['ORG_LAT'] = str(surf_lat)
myfmeCS = myCSMan.defineCoordSys(fmeParams, "myfmeCS")
Now I am at FME 2024 where pyfme has been replaced by fmeobjects. So I made the changes like below:
import fmeobjects
myCSMan = fmeobjects.FMECoordSysManager()
#defineCoordSys only takes one parameter
myfmeCS = myCSMan.defineCoordSys(fmeParams)
The last line gives this error:
Message Type: fme::internal::_v0::py::Exception
Python Exception <TypeError>: Could not convert Python coord system parameters.
Error encountered while calling method `input'
PythonCaller_5 (PythonFactory): PythonFactory failed to process feature
Any idea?
Allen
Best answer by david_r
The problem is that the method defineCoordSys() has changed, it now takes only coordSysParms (a dict[str, str] or pairwise list[str]).
Try something like this:
import fmeobjects
# Define custom CRS
# Static parameters
fmeParams = {
'CS_NAME': 'local_polyconic_cs',
'DESC_NM': 'Dynamic CS',
'DT_NAME': 'WGS84',
'PROJ': 'PLYCN',
'UNIT': 'FOOT',
'X_OFF': '0.0',
'Y_OFF': '0.0',
'MAP_SCL': '1.0',
'SCL_RED': '0.9996',
'SOURCE': 'HESS',
'QUAD': '1',
'ZERO_X': '0.0001',
'ZERO_Y': '0.0001',
# Dynamic parameters
fmeParams['PARM1'] = str(feature.getAttribute('surf_long'))
fmeParams['ORG_LAT'] = str(feature.getAttribute('surf_lat'))
# defineCoordSys now takes a single arg and returns the unique CS name
cs_name = myCSMan.defineCoordSys(fmeParams)
See also https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_coordsys/fmeobjects.FMECoordSysManager.defineCoordSys.html#fmeobjects.FMECoordSysManager.defineCoordSys
  • Feb 9, 2026 2:49 PM UTC
import fmeobjects
# Define custom CRS
# Static parameters
fmeParams = {
'DT_NAME': 'WGS84',
'PROJ': 'PLYCN',
'UNIT': 'FOOT',
'X_OFF': '0.0',
'Y_OFF': '0.0',
'MAP_SCL': '1.0',
'SOURCE': 'HESS',
'QUAD': '1',
'ZERO_X': '0.0001',
'ZERO_Y': '0.0001',
aguan
  • Feb 9, 2026 4:08 PM UTC
​@david_r That seems to work, thanks a lot.
