I'm having a recurring issue where FME Workbench 2018 crashes after 2nd or 3rd attempt to publish to FME Server. I have a whole bunch of workspaces that needed mods and subsequently uploaded to FME Server, but workbench crashes after 2nd or 3rd upload consistently. I also observed that it doesn't matter if it's a new publish or a re-publish, it still causes workbench to crash.
If you look at the log in the screenshot it reports that it published successfully, but generally I don't trust it so will re-upload the crashed one just in case the workspace on the server got corrupted.
Normally this is not a biggie if doing solitary workspaces, but when you have to upload a couple dozen then it becomes a bit of a pain. I'ts been happening for us on various PCs and as far back as FME 2015 (from memory).
Would love to know if others are getting this and a possible solution?
Thanks!
