FME Workbench 2007
  • Apr 13, 2013 7:44 PM UTC
  • 43 views
My company will not move forward on using FME Workbench 2013 until it is confirmed as working well with our newest version of GE Smallworld.  I'm always converting geometry data from AutoCAD Map into GE Smallworld data. I have to save the ACAD file as a version 2000 so Smallworld can read it. Can anybody tell me if there is a FME Workbench 2007 manual that I can find so I can better understand how the transfer of data from ACAD to GE Smallworld is setup?
I would appreciate this greatly for the help!
Paul21,
  • Apr 14, 2013 7:26 AM UTC
Try here http://goo.gl/51qKF
  • Apr 15, 2013 7:50 AM UTC
remember that it is possible to have several versions of FME installed on the same machine, without interference. Just remember to install them into separate directories.
This is extremely handy if you need to test for compatibility between versions, such as it seems to be the case here.
David
