FME Server security with password encryption and decryption
  • Nov 23, 2017 3:35 PM UTC
  • 246 views
Good afternoon everyone,
I have one question regarding FME Server security. I am using FME Server 2014 with an Oracle database.
Normally when we create a user in FME Server, the user is create in table FME_USERACCOUNT with an encrypted password.
Now I have an issue that one of my web services have to access FME Job so my web services need username / password for basic authentication.
Now I have two options either I store password in some local storage with my web service or my web service access Oracle schema fmeserver and get password for user. If i can have decrypted password, the management will be very simple for me.
Can anyone guide me, may be I am missing some basic point over here.
I don't have AD in my infrastructure.
Can you please guide me ?
Regards
  • Nov 23, 2017 3:46 PM UTC
Rather than using basic auth, you should look into using a security token for your API access.
Here are a couple of starting points:
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/ReferenceManual/service_token.htm
https://playground.fmeserver.com/getting-started/authentication/
Thanks David, but even for that I need a password. I look at the documentation and to generate a token as well I need to have password for user.
  • Nov 23, 2017 4:21 PM UTC
It all depends on the security level that's necessary for your environment.
One solution could be to manually generate a security token with an "indefinite" validity and store the token in your database. The security token should be generated for an "API-only" user with extremely limited rights.
Some arguments for this solution:
  • More convenient, as you can easily expire or regenerate tokens without affecting the API user's account password.
  • A secure password (as in Basic Auth) is basically identical to a secure token. Using the token you don't need to store the username in your database, one less thing to worry about
Hi @ayyaz_paracha,
Do you know the password for this user?
Once you've generated the token you wouldn't need the password.
Another thing you could look at is using the Guest User
